Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 06-19-2006, 07:15 PM
andrews4691 andrews4691 is offline
code p0404
'06 king ranch 6.0 showed code p0404 according to Advanced Auto Parts do i need to be concered
Old 06-19-2006, 07:28 PM
mschn99 mschn99 is offline
thats an EGR code....do you have any mods??
Old 06-19-2006, 07:42 PM
none i had a heavy load pulling mountains last nite. should i be worried
Old 06-19-2006, 07:43 PM
nothing to "worrie" about, but u should get it in, odds are it needs an EGR valve.........Marc
Old 06-19-2006, 07:45 PM
dfuser dfuser is offline
It all depends what is actually wrong with the EGR. I have seen a couple bad EGR's cause more problesm, such as loss of power and so forth.
Old 06-19-2006, 07:46 PM
usually a p404 is just a stuck closed valve though, which shouldnt cause any drivability problems.........although ive learned with the 6.0, anything is posible...
Old 06-19-2006, 07:50 PM
when aap checked the code the light went off if it comes back on ill take it in (which will have to be soon 71k on her out of warranty soon)
Old 06-19-2006, 07:53 PM
up to 100k its all the same, and if i was you i would do everything within your power to try and re create the problem to get the light back on, it will be considerably cheaper that way. this is one of the problems of letting someone pull codes for you....if you hit the dealer with taht code, it will $100 deductable and they will fix it up to 5 years or 100k.........Marc
Old 08-01-2006, 07:35 AM
jdnotchback jdnotchback is offline
wahts the parts # for the correct egr
Old 08-01-2006, 05:43 PM
i dont know part numbers off the top of my head. there are two different EGR vavles for the 6.0 depending on build date as well...
