2004 F-350 No Start - Ford Powerstroke Diesel Forum
post #1 of 55 Old 08-31-2007, 09:05 PM Thread Starter
2004 F-350 No Start
How do I diagnose a no start condition? What are the best steps to take? Thanks.
mtman is offline
post #2 of 55 Old 08-31-2007, 09:16 PM
Beer Drinker/Ballast Guy
clmtng's Avatar
Key...ignition...turn.
No really I don't know what else to look at. I'm sure that there's someone here that's still sober.:beer2:
99.5 F-250; Garrett GTP38BB Turbo; 4" MBRP Exhaust; 2" Leveling Kit; AEM Air intake; ZooDad Mod; Foil Delete; AutoMeter Z series gauges, pyro, boost, trans. temp w/piller pod, muffler delete, Tunes by Tony Wildman; Recon tail lights and third brake light; Headlights from Raul; Twinkle mod // Soon to be: winch
clmtng is offline
post #3 of 55 Old 08-31-2007, 09:21 PM
jfines@cox.net's Avatar
Is the starter turning the engine?
Jody in Mesa,Az
97' crew cab xlt, F350
7.3L PSD
Long Bed
2 wheel Drive
3 gauge pillar(egt,boost,trannytemp)
3" down pipe
DP Tuner
CAT Delete.
Tranny Rebuid ( 3 disk TQ, extra clutches, all billet steal internal parts, New HD Valve Body, 45,000 BTU cooler)
37' Avion 5th Wheel
jfines@cox.net is offline
post #4 of 55 Old 09-01-2007, 07:20 AM Thread Starter
Yes. The motor cranks & turns.
mtman is offline
post #5 of 55 Old 09-01-2007, 07:41 AM
With mine, when it wouldn't start, I thought it was the batteries, charged em and no go, turned out to be the starter, gotta spin the engine fast to start it.
Easiest steps first, check your oil, make sure it is full, then check the oil level in the HPOP. Then I would check to see if your getting fuel.
Also, do you hear your glow plug relay cycling, and have you checked to see if the computer has any codes?
Jody in Mesa,Az
7.3L PSD
Long Bed
2 wheel Drive
3" down pipe
DP Tuner
CAT Delete.
37' Avion 5th Wheel
post #6 of 55 Old 09-01-2007, 08:11 AM Thread Starter
How do I check oil in the HPOP?
mtman is offline
post #7 of 55 Old 09-01-2007, 08:20 AM
If my memory works like it used to, There is an bolt on top of the HPOP (high pressure oil pump) you pull it and look inside. If it is low, add some oil directly to the pump.
But that is from memory, hopefully on of the techs will chime in, But I think most of them went to Diesel in the Desert. I'd be there if I didn't have to work.
Jody in Mesa,Az
7.3L PSD
Long Bed
2 wheel Drive
3" down pipe
DP Tuner
CAT Delete.
37' Avion 5th Wheel
post #8 of 55 Old 09-01-2007, 08:41 AM Thread Starter
I don't have a code scanner. I heard the Ford has to have a specified reader to retrieve all the codes. How do I know I'm getting the right thing?
mtman is offline
post #9 of 55 Old 09-01-2007, 08:52 AM
Well, I know autozone's won't get all of them. I use a snapon, but don't recomend buying it just for one vehicle, Cost about $5,000 with all updates to 07.
As for any other types, I don't know.
Jody in Mesa,Az
7.3L PSD
Long Bed
2 wheel Drive
3" down pipe
DP Tuner
CAT Delete.
37' Avion 5th Wheel
post #10 of 55 Old 09-04-2007, 08:45 PM Thread Starter
Can someone post a pic of what the HPOP looks like on a 6.0?
My batteries are definitely weak. Were the OEM batteries Motorcraft and do they look just like the ones in the autoparts store? Who makes the Motorcrafts batteries?
mtman is offline
