2005 E350 help needed asap - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-29-2007, 03:22 PM Thread Starter
99CrewPSD's Avatar
My 05 E350 has a 6.0 psd and this morning it had problems cranking.well i changed the oil today and just drove it 40 miles and had to come back to my jobsite and when i got here and shut it off...and went to start it back up and all it will do is turn over.i have tried to crank it 10-15 times over the last half hour and it just spins.......im stuck here 100 miles from home and need some suggestions.
there are no codes or CEL being thrown either
thanks
Brian
2001 ECSB F250
Little bit of this and a Whole Lot of THAT
99CrewPSD is offline
post #2 of 5 Old 08-29-2007, 03:27 PM
Do you have enough oil? Are any fuses blown? Are you sure its your van?
2005F250 is offline
post #3 of 5 Old 08-29-2007, 03:53 PM Thread Starter
99CrewPSD's Avatar
oil is good.fuses are good,its my van
2001 ECSB F250
post #4 of 5 Old 08-29-2007, 04:07 PM
ADMIN AND TECH
SCUFFY828's Avatar
being that it is a 05 model if i had to guess , there are two things ive been seeing alot of on the vans , why the vans i dont know , but on the right side of the engine in the oil rail to the injectors there is a plug , there are two o-rings on this plug , the bottom one has been blowing out , like i said i dont know why on a van , but ive had six in three months with no high pressure opil and that is what i found , maybe the extra heat, i dont know , but the other thing is the high pressure oil pump fitting blowing out , the only thing that doesnt make since is you say you dont have any codes , is the scanner your using able to pull the cods correctly for this 6.0 engine , some scanners will pull generic codes but wont allow you to pull ford specific codes , only other thing thats possible would be fuel pressure , i have replaced a few fuel pumps , make sure pump is running , im curious what it turns out to be so keep us informed
ITS STOCK
SCUFFY828 is offline
post #5 of 5 Old 08-30-2007, 03:19 AM Thread Starter
99CrewPSD's Avatar
Im sending it to ford this morning.I will let you know what it is.thanks guys
2001 ECSB F250
