Help remove codes.. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-29-2007, 01:44 PM Thread Starter
BrtCaptain's Avatar
Help remove codes..
My 04 f250 is going in shop for egr problems...I had a Edge chip and it has been removed.. Question how do I clear the codes? If they flash it will it show codes thus voiding my warranty?
04 F250, 4" MBRP, Airaid, Zoodad Mod, SCT X3, 6" lift
BrtCaptain is offline
post #2 of 6 Old 08-29-2007, 02:38 PM
Powerstroke W/smoke's Avatar
i would like to know how to do this too so when i get my chip and it breaks something i can hide it
Sold!2001 F-350Lariat Lifted 7.3L CC, 5" Straight Pipe, DIY Intake, Foil-Delete, 6 pos chip, CCV Bypass, 37" Toyo MT, Gauges, Blacked out, 07 Harley Front-End.
SOLD!2006 F-250Amarillo 6.0L CC, 4" Straight Pipe, SCT-II
STOLEN ,2001 F-350Lariat 7.3L CC, 6pos chip, 4" Banks Straight-Pipe, Banks Comp Wheel, Custom Lighting, Foil-Delete, Intake.
Powerstroke W/smoke is offline
post #3 of 6 Old 08-29-2007, 02:45 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 2 Post(s)
you can unhook the batteries for a little bit and then rconnect them, the only problem is it will have to be driven at least a hundred miles or so to run it thru enough drive cycles to allow the pcm to show a pass code or even the code for the problem you have , if you take it in with out drive time it will show a p1000 code and they will know its been tampered with
ITS STOCK
SCUFFY828 is offline
post #4 of 6 Old 08-30-2007, 02:54 AM Thread Starter
BrtCaptain's Avatar
Thanks
Thanks for the info, to bad my truck won't run... hopefully they will miss the codes.... I have a new '08 ordered and it should be in soon... I'm going to have an SCT put on the 04 when it comes back..
post #5 of 6 Old 08-30-2007, 03:04 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 2 Post(s)
sorry about that , yes they will know, hopefuly they wont be an a$$ about it
ITS STOCK
post #6 of 6 Old 08-30-2007, 03:08 AM Thread Starter
BrtCaptain's Avatar
Will poo happens.... should have done a little more research. Just have to pray that the heads arn't boogered..
