Burned Harness Plug - Ford Powerstroke Diesel Forum
Old 08-29-2007, 07:37 AM
Exclamation Burned Harness Plug
Anybody know if the wire harness connectors that plug into the valve cover gaskets are replaceable or do I have to replace the whole harness? Problem I am having is, truck goes into limp mode, runs rough and the CEL comes on, no codes with my scanner. While reading other posts to this forum, I decided to inspect my connectors to my gaskets. Found one burned! This a great forum, saved me alot of repair costs. THANKS
Just tri'n to keep it go'n 95' F250 4x4 5sp man PSD 255,000 miles.
Old 08-29-2007, 07:40 AM
Desert Shield/Storm Vet
Im not sure if you can just get the plug but the haness and plug is pretty cheap should be less then 40 bucks.
Old 08-29-2007, 07:48 AM
Here ya go someone posted this up the other day. Scroll down about 3/4 of the way it the parts you need are listed Oregon Fuel Injection, your diesel fuel injection specialist, rebuilt turbochargers, injectors, pumps and diesel performance products.
Old 08-29-2007, 07:56 AM
I just priced the parts from my local ford dealer, 529.00, Thanks for the info!
Old 08-29-2007, 07:59 AM
Wow stear clear of that dealer
Old 08-29-2007, 08:28 AM
Just ordered the repair parts I needed from Oregon. A lot less thanks again.
Old 08-29-2007, 12:14 PM
You bet
