No oil pressure at idle, need help!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-14-2011, 09:38 AM Thread Starter
kmesaeh's Avatar
Exclamation No oil pressure at idle, need help!!!
I just changed #3 injector on my 99.5 F-250 with 7.3. Before taking it for test drive I had pressure at idle, drive truck for about 3 to 4 miles stopped at stop sign and noticed that I no oil pressure when idling. It also seens to be low on power and running rough, could be due to air in system but not sure. Did not have the issue before replacing the injector.
kmesaeh is offline
post #2 of 5 Old 10-14-2011, 10:10 PM
there's a couple places to look for the problem, but first look at anything new. Why the injector change? Could the new injector be leaking off the high pressure oil? is it seated correctly, and new o-rings with the new install?
The 7.3 has a weak point with the oil pick up tube either coming loos or cracking and allowing air into the hi pressure oil, but if if wasn't this type of problem before changing the injector, it's unlikely. I would be looking at the new injector install.
STUPAGE is offline
post #3 of 5 Old 10-15-2011, 12:54 PM Thread Starter
kmesaeh's Avatar
Ok, I changed the sending unit and the connector. i also put a mechanical gauge to the test port at the filter housing, and went for a drive. I still have the same problem, I noticed that the gauge was dropping to under 5 psi at idle. At this point, I'm even more stumped!!
kmesaeh is offline
post #4 of 5 Old 10-16-2011, 08:24 PM
You've gotta look at something that changed with the injector install - I would go back and take it out and look at everything that was touched. It could be coincindental, but highly unlikely.
Look up the "Coffee Table Books' these are technical mannuals with great pics that are a great help with lookinfg at systems. you can find them on any of these sites/logs
STUPAGE is offline
post #5 of 5 Old 11-16-2011, 02:54 PM Thread Starter
kmesaeh's Avatar
Ok sense my last post I attempted to drive the truck arround the block, lost oil pressure. would not build any pressure when cranking. I changed the oil and filter, no change. I installed a new low pressure oil pump and still no change. There has to be some flow from the pump cause the filter is full. the gauge I have moves very little, not even to 1 psi, but comes off 0 when cranking. I have no clue what to check/look at now.
kmesaeh is offline
