P115A stuck on road
So last night a friend of mine was stopped on the side of the road. He shut off his truck. 2006 6.0/auto/4x4. Its got an Edge A2 in it if that helps at all. He tried starting his truck back up and it would just turn over....but not start up. The Edge A2 pulled the code P115A....which is saying low fuel level/forced limited power. He told me the only thing that he could think of is he ran dangerously low the other day on the interstate to the point where it was sluggish as he pulled in to fill it up. After he filled it up, he's run for maybe 4 days and its been fine. So the most we did last night was change the fuel filters which, the lower one was the only dirty one.....still wouldn't crank. This morning he got some batteries for it which needed replacing anyways....It cranked right up. (btw, before i got there last night i told him to pull the cables off the batteries...thinking perhaps it'd reset the computer...didnt work) Now, he ran it for a bit this morning and cleared the codes....Shut it off...now it wont start again....
What is going on? need help ASAP. Thanks, Alex |
have you guys tried disc. the Edge?
not yet...you think that could be a culprit?
its worth a try.....my sensor for my juice that connects to the cam sensor went out a few months after i installed it and wouldnt start my truck and sometimes it would run like crap.... i would do that since its easy and FREE and see if it helps
-Raul |
Alright good deal. I'll tell him to give that a shot.
ANYMORE HELP WOULD BE GREAT!!!
THANKS ALEX |
FOR ANYONE THAT HAS HAD THE SAME PROBLEM....IT TURNED OUT TO BE THE HPOP(HIGH PRESSURE OIL PUMP). ABOUT 10 HOURS WORTH OF WORK @ FORD.
Thanks for anyone who tried to help, Alex |
Glad you got it figured out....
