What is wrong with my 7.3? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-12-2011, 06:40 PM Thread Starter
Some background..2001 excursion 115k miles cp chip mbpr exhaust banks turbo....
Labor day weekend taking the fam camping (first time with this truck). My f150 pulls our trailer no prob, anyway the truck is struggling egt is pretty high, we stop for a short break (truck does not get shut off) go on our merry way and 2 mies down the highway just dies...cranks ,no start, no check engine light...nothing. So I try a few simple fixes including a cps to no avail. Take it to the shop they tell me no injector pressure replace the IPM and the ICP and viola we are on the road again...for a day. Driving normally and it dies again, pop it in nuteral and it fires right back up...take it back to the shop immediately and they tell me cps I say I just did one they tell me needs to be a ford part (no a ford shop). Ok so they do it all dandy again for a day drove it this morning no problems, fire it up this afternoon drive about a quarter mile and the rpm's drop like a rock and it is struggling, flip the chip to high idol and it can't even push past 1000 rpms. Finally it breaks loose, I drive to where i need to go and the truck sits running for about 30 minutes. On the way home get about a mile down the road and the rpms drop again...get it semi normal again and head for home...2 miles later I am limping egt is 900-100 trans temp is about 190 and if I try to go any faster than 10 mph the thing sounds like it's gonna fall apart....any ideas what the heck is going on?
macsdaddy is offline
post #2 of 18 Old 09-12-2011, 07:10 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Check the UVCH and connections.
By IPM you mean IPR maybe? And what else did he say other than no injector pressure? Did he even know what he was talking about?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 18 Old 09-12-2011, 07:17 PM
belz's Avatar
Quoted: 68 Post(s)
Check the wires also going to the icp. Did u by the truck new or used? I had a bad wire going to my icp and had lots of issues. Even showed no injector pressure while the truck was running.
Sent from my fone.
Belz
CPA Director
belz is offline
post #4 of 18 Old 09-12-2011, 07:23 PM Thread Starter
My fault injector pressure regulator..beyond the injector pressure he said they had read some codes during the first repair..sadly I was preoccupied by my 1 y.o and did not hear him. I bought the truck used a month and a half ago I had no issues before this crash...another trigger that may have (just grasping at straws here) had a DVD system and head unit installed the week before. The mech told me the ipr was a separate system so the chances of that screwing it up were slim. This mech came highly recommended by someone who's opinion on this I very much respect and happens to drive a 7.3 owner too....can you point me to the uvch?
post #5 of 18 Old 09-12-2011, 07:48 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Yea doubt that DVD cause it.
Belz is right about the IPR.
There is a plug going into each valve cover, about in the center, with 8 pins each. 4 for glow plugs, 4 for injectors. Check to make sure the connection is tight and that none of the pins are burnt.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 18 Old 09-13-2011, 04:42 AM Thread Starter
Icp or ipr? I checked the ipr plug on the drivers side is there another one?
post #7 of 18 Old 09-13-2011, 07:14 AM
belz's Avatar
Quoted: 68 Post(s)
Mine was wire going to icp. Truck would start stumbling and I would lose throttle response at random. Sometimes it would shut off others it wouldn't. I got to the point where I would shut it off and crank it back up rolling done the road. It was easier than trying to stop with the truck off.
Sent from my fone.
Belz
CPA Director
belz is offline
post #8 of 18 Old 09-13-2011, 03:56 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Meant the UVCH
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 18 Old 09-13-2011, 07:04 PM Thread Starter
Well after a day at the shop the tech told ke it's thrown number of codes that he's gonna asses and troubleshoot in the morning...grr
post #10 of 18 Old 09-13-2011, 07:21 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Could you list what codes?
4R100, 2wd
330,000 + miles
jesilvas is offline
