need help with my fuel leak
OK guys I need a little help. I have a fuel leak, leaking into the rear of the valley,very hard to see with mirror and flashlight,removed pass side IC pipe, now I can watch it drip(with mirror,while running), the highest point I can see fuel dripping from is on the fuel line on the pass. side(part # 9B273),it is dripping off of the elbow that is blocked by the square box in the picture.
Does anyone know if there is a common leak point above that, where it could be coming from that I can't see? Or is the fuel line likely ruptured? It leaks a lot when running. I have tried to look up the fuel line in both directions, and can't find the leak up any higher. Sorry I suck at getting pictures up here, I don't know how, but i'll deal with that problem later. I'll be taking it apart while I wait for any responses. Thanks a lot guys chris |
Corroded O-rings
I had the same problem with my 99. The new diesel fuel is corroding the o-rings in your fuel lines. There are 5 or 6 to be replaced. I bought my kit on e-bay alot cheaper than at the Ford dealer. There are 4 o-rings in your fuel rails and a couple in your filter housing. The ones in back were the hardest to replace but with a little determination it can be done. Pick up a good Chilton or Haynes manual. It will help with the removal of the filter housing etc. This should cure your problem it did for me.
I think you are talking about the fuel drain valve? it is on the back side of the filter housing. Has a yellow handle. They are common for leaking fuel into the valley.
I have seen holes rubbed in those lines by the support strap that hold the line in place.
Well fatty2309 was the closest.
I am soooooooo pissed right now. I knew that the O-rings probably should be replaced, but I knew that the leak was not coming from either end of the line, it was somewhere in the middle. It was either something dripping down onto it, which I could not find, or it must have been a hole in the line somewhere. Well i'll be dipped in sh!t, there is hole in the line! right next to my NEW HPOP supply line. The one that the shop replaced for free on good faith. I took everything off the top of the motor and removed the fuel line(Lugen was right, pain in the butt) When I looked at it, there was a gouge out of it near where this oil supply line is. I submersed the line in water except for the ends, plugged one end with my finger, and blew into the other end, sure enough! bubbles right where the gouge is!! SON OF A..... The moral of this story is --- Never let anyone work on your truck, but you! Even if it is free! For the record fatty2309, it is worn a little where the support clasp goes. thanks for the tip. Thanks for letting me vent guys. I feel better, sorta. I'm going to see what Ford wants for a replacement line. If it's too much, i'll just J.B. Weld it and get new O-rings. If I can get my wifes camera to work, I'll post some pictures of the line and the O-rings that came out of it. Thanks to all for the quick replies chris |
Glad you got it figured out. Good luck on the fix.
Its recommended to replace the line but if its too high which i highly dought it. You could have it braised (how ever you spell it). it will hold better & longer than JBWeld. Course i can't do that procedure at our Ford shop, its against our policy.
Quick update:
Go the new fuel line in and everything put back together last night. $52 fix, and no more leaks! Thanks for the replies! |
Sorry I did'nt respond back so soon. I'm glad you found & repaired the leak. These trks. are sometimes hard to find oil & fuel leaks. Congrads to you!!!!
Does anyone know what fittings are used on the fuel lines from passenger side of fuel bowl? They appear to be standard 1/4" tubing fittings. I ask because after installing my Stealth kit, my fuel lines had to be removed and I would like to get some flexible ones made. Thanks for the help.
