**TURBO OVERBOOST!!** - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-18-2011, 11:15 AM Thread Starter
I have an '06 F-350 6.0L a week ago I did an EGR delete from BD and S&B air intake plus the H&S mini maxx. over the weekend i was pulling a four place sled trailer loaded (about 5000lbs small load) and a couple of times i hit 32lbs of boost then the service engine light would come on and the engine would cut back to 24lbs boost and little power. shut the truck off clear the code with my mini maxx, start the truck and all was fine for a few days then same thing again. Has anyone else ever had this or does anyone know what or why it could be? im kinda stumped as my thoughts are it is in the electronics. and also i was running in the mild and the wild tune settings, not the Hot!
M7plus is offline
post #2 of 11 Old 04-18-2011, 11:19 AM
2003kingranch's Avatar
i didn't even know 6.0's had a over boost feature . subscribed
did you un hook the minimaxx and try driving it? i dont know if your truck will hit 32 psi stock. i know mine would if i was pulling something.
your the first person ive herd with a minimaxx on a 6.0. i was looking at them. how does it run?
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #3 of 11 Old 04-18-2011, 11:38 AM Thread Starter
when the truck was stock 20-22lbs was about the most i would see pulling the 36ft fifthwheel. even with the mini maxx normally only 25-28lbs, and it wasnt even on big hills or hard pulls when it would spike up and then until i reset the code it would sit right around 18-24lbs not even working(where normally would be 4-9lbs). i haven tryed without the chip to see if it will do it yet. i like the mini maxx on the 6.0L with the air intake on the HOT tune loads of power and hardly any black, (not a big fan of reducing granny's visibility in the car next to me) i had the tripple dog before but its hanging in the garage keeping dust from landing on the floor! the shift on the fly is really nice and being able to monitor all the perameters and set defuel levels is pretty sweet as well, plus its small and easy to mount on the dash and thieves cant really see it!
M7plus is offline
post #4 of 11 Old 04-20-2011, 09:26 PM
03Powerstroker6.0's Avatar
there is no overboost code on a 6.0. the motor will handle 30lbs of boost fine, i push 35 no problem empty on canned or custom tunes. on stock its around 25lbs empty
03 F350 Lariat CC LB 4x4,
straight Pipe 4" exhaust 6" tip
3" front lift
5100's bilstiens
high idle mod
Sct Gearhead tuned,
EGR deleted
trans,fp, boost, egt, ect, eot gauges
vgt switch
2low Switch
Zoodad
315/75/16 baja claw
Custom trac bars
coolent filter
ccv mod
arp studs by me
afe stg 2
fuel bb mod
Hids
Smoked LED tails/3rd
Harley headlights
Smoked led tail lights
08 T gate
Upgraded banjo bolts
2 12" subs/6x8 infinity speakers
JD cool Gaurd II coolent
03Powerstroker6.0 is offline
post #5 of 11 Old 04-20-2011, 09:53 PM Thread Starter
If there is no code for over boost on a 6.0L then someone must have slipped a durtymax under my hood when I wasnt looking! It happened on 2 different occasions, I hit 30-32lbs and my sevice engine light came on and it de-rated itself! when i checked the codes with my mini maxx i cant remember the code number but the code read "turbocharger overboost condition". I'm not saying your wrong but I'm just telling you what i seen and if anyone else has had this problem help would be great! maybe i need to get H&S to wright me a different tune to over ride this code or not to make that much boost, I dont know.
M7plus is offline
post #6 of 11 Old 04-20-2011, 09:58 PM
im probably wrong, map sensor is reading higher than normal and truck is defueling, chip is causing this or stuck vanes are. run it stock check results
3" front lift
5100's bilstiens
high idle mod
Sct Gearhead tuned,
EGR deleted
vgt switch
2low Switch
Zoodad
315/75/16 baja claw
Custom trac bars
coolent filter
ccv mod
arp studs by me
afe stg 2
fuel bb mod
Hids
Harley headlights
08 T gate
post #7 of 11 Old 04-20-2011, 10:01 PM Thread Starter
03powerstroke6.0, can i ask what the zoodad mod is and also how you did the high idle?
M7plus is offline
post #8 of 11 Old 04-20-2011, 10:04 PM
zoodad is cutting out the plastic right infront of your stock air filter box towards the front of the truck, allowing air to be rammed into the air filter as you drive, high idle, theres two wires under the dash, you'll have to look up which ones, when you run them to a switch, switch on idles the truck up to 1200 rpms, which can serve many purposes.
3" front lift
5100's bilstiens
high idle mod
Sct Gearhead tuned,
EGR deleted
vgt switch
2low Switch
Zoodad
315/75/16 baja claw
Custom trac bars
coolent filter
ccv mod
arp studs by me
afe stg 2
fuel bb mod
Hids
Harley headlights
08 T gate
post #9 of 11 Old 04-20-2011, 10:07 PM Thread Starter
Sweeet I did the zoodad when i put my intake on last week and didnt even know it then! and thanks I will have to figure out which two wires they are that would be really handy up here in canada for our 8 months of winter!
M7plus is offline
post #10 of 11 Old 04-20-2011, 10:09 PM
yup, warms it up much faster than idling
3" front lift
5100's bilstiens
high idle mod
Sct Gearhead tuned,
EGR deleted
vgt switch
2low Switch
Zoodad
315/75/16 baja claw
Custom trac bars
coolent filter
ccv mod
arp studs by me
afe stg 2
fuel bb mod
Hids
Harley headlights
08 T gate
