where do I put my T.W. chip on a 97??? - Ford Powerstroke Diesel Forum
Old 07-10-2007, 04:18 PM
help I just want to put my new tony wildman chip in and Where do I
plug it in.??? on a 97 the video shows a 2000?? and I dont have a computer there.
Old 07-10-2007, 04:23 PM
BIG TRUCK, SMALL DRIVER
The ECM is located behind the parking break pedal. You have to access it from under the hood. You can see the harness going to it under the steering column. You may have to partially remove the inner fender well to pull it out.
Old 07-10-2007, 04:38 PM
thats what the video shows but mine is not there???!!!
Old 07-10-2007, 04:41 PM
Do you see two big wire harnesses going into the firewall under the steering column?
Old 07-10-2007, 04:44 PM
yes there are three but they just go to wires on the inside that run up.
Old 07-10-2007, 04:56 PM
Just looked again nothing there.Remember this is a cali 1997
Old 07-10-2007, 04:57 PM
You will not be able to see it from inside the cab. It is behind the aliminum dash support bracket. It's the one closest to the driver-side fender. You will see a stud with 10mm nut just above the harness. Back the bolt out of the center of the harness, then remove the 10mm nuts, one on top, one on bottom. Then you can pull the ECM out of it's pocket.
Old 07-10-2007, 05:03 PM
thanks I see it now..
Thanks for your help I kept thinking you pull it out from inside.
Old 07-10-2007, 05:15 PM
No problem! You may be able to get it out without moving the inner fender, but I had to take all of the screws out of mine from the 12 o'clock position down to the 4 o'clock and pull it down. Good luck and make sure you clean the contacts good.
Old 07-10-2007, 06:37 PM
I cleaned them to shiny metal duct tape it in and reinstalled but now my wait to start light will not go out and my truck will not start
