P1211 & P1280 - Ford Powerstroke Diesel Forum
post #1 of 43 Old 07-10-2007, 06:31 AM Thread Starter
P1211 & P1280
Hello everyone.
My truck has been feeling liek the power was falling off the last week or so. Wrote it off to hot weather, and actually working it (hualing firewood, etc...)
Sunday after a day at the lake , got off the freeway and everything fell apart. Got a cam sensor code when I came off the throttle (replaced the sensor, no change).
Now I am getting P1211's & (1) P1280 (uncontrollable icp, & icp low). Will not hardly run/start when warm, starts cold and has some power, but is still not right. Fuel pressure hold at 60 psi under throttle, but bounces from 60-100+ when fighting to idle (surge & sputter when warm). I do not have a guage to monitor ICP pressure.
Went back to stock programming, no effect.
Oil has 2400 miles +/-, and is full.
Exhaust "smells" good, not rich or anything. Still can get Low sulfur here & run cetane boost always.
99.5, 4x4, auto, 4" exhuast, (dreaded) K&N intake, Superchips 1705 usually in Tow safe mode.
Please help, do not have money to throw at it!!!!!
Ides is offline
post #2 of 43 Old 07-10-2007, 06:36 AM
ADMIN AND TECH
SCUFFY828's Avatar
check the wiring going itno the icp conetor make sure its not frayed , very possible icp sensor bad internally , would give that 1280 code , p1211 can be caused by 1280 code, address 1280 first
ITS STOCK
SCUFFY828 is offline
post #3 of 43 Old 07-10-2007, 10:14 AM Thread Starter
Thanks Scuffy.
I did pull the plug from the sensor last night. No change (at least in the driveway) in running, but the check engine light stayed on.
The check light does not come on until I just drop my foot into things, which is currently required to get it rolling 70 once warm.
I will make a more thorugh visual of the connector.
The P1280 code has only come up once, while the 1211 is pretty consistent.
Ides is offline
post #4 of 43 Old 07-10-2007, 10:27 AM
ADMIN AND TECH
SCUFFY828's Avatar
sveral things can cause , p1211 , low fuel pressure , bad oil quality , and ipr problem can sometimes , maybe split o-ring on ipr, just have to sart eliminating
ITS STOCK
post #5 of 43 Old 07-10-2007, 10:42 AM Thread Starter
Thanks Scuffy.
Will inspect things tonight and post what I find.....
99.5 F-250 XLT 4X4 , 4" Lift, Auto, Crew, Long Box, Superchips, 4" Exhuast, 203 Thermostat, K&N Intake, Tint, Limo Tint in Back, Rhino Liner, Rhino Lighted Chrome tubular "long" steps, 97,000 Miles, 315/75 BFG's
Ides is offline
post #6 of 43 Old 07-10-2007, 10:55 AM Thread Starter
Checking the O-ring...
Any good advice on how to check this? I have a Chilton's but it is rather lacking... Have not looked for this in that manual yet, need to get home first, but maybe someone has some good techniques/tips that are not always listed.
Thanks any/everyone!!!
Ides is offline
post #7 of 43 Old 07-10-2007, 05:23 PM Thread Starter
Checked all the sensor connections, visually everything is fine.
Checked IP O-ring areas, all clean.
Unhooked ICP sensor, and took the truck for a drive. Except for a bit of smoke around idle and a definate rich smell, it performed (or lack of) exactly the same, getting worse as it came up to temperature.
Constant check engine with sensor unhooked, coded the same codes, 1211 & 1280 as i get with it hooked up. I cleared the codes before running it, so those were fresh to the no sensor run.
Is this a good indicator the sensor fried? And is just within spec enough to not pull a constant check engine when hooked up?
I am running Delo 400 for oil, it is several hundred ahead of change. Oil does not smell and looks pretty clean.
All input appreciated.
Ides is offline
post #8 of 43 Old 07-10-2007, 05:51 PM
ADMIN AND TECH
SCUFFY828's Avatar
did you pull the ipr out of the back of the pump , and look at the green o-ring on it
ITS STOCK
post #9 of 43 Old 07-10-2007, 07:18 PM Thread Starter
Ok, and Nope.
Anyone got a good link on location?
Sorry guys, I have only had the truck for a little over a year, still learning to deeper parts......
The crappy chilton's manual only tells you to remove it if replacing the whole pump unit. Is this going to require removing the pump, lines, etc?
Thanks Scuffy
Ides is offline
post #10 of 43 Old 07-11-2007, 03:00 AM
ADMIN AND TECH
SCUFFY828's Avatar
do not have to take pup off, disconect two wire connector, use 19mm wrench or 3/4 and take the nut off the back, slide the solenoid off the end , then with a 1 1/16 socket take the ipr out of the pump inspect o-rings , if look ok reinstall, if there is a problem its usually fairly obvious with the o-ring
ITS STOCK
