Gas in diesel in 7.3 - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-16-2011, 07:14 AM Thread Starter
So I get a call this morning from one of my guys telling me he put some gas in the truck on accident. After finding out that he added 13 gallons to an empty tank I told him to fill the rest of the truck with diesel add two quarts of ATF and baby the truck back to the lot. I was going to keep running the truck till 3/4 of a tank and topping it off for a while than changing the fuel filter in a 3-4 weeks. Just wondering if this is ok...I really can't afford to blow the motor in this truck as the only work I have this time of the year is plowing and we've only had two good storms this year. Any help would really be appreciated thanks guys
445ci is offline
post #2 of 19 Old 01-16-2011, 07:18 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
That is a lot of gas to try to dilute. If it were me I would drain the tank and refill with diesel assuming that he has not drove it yet.
As much as these engines cost and if you rely on it for work then dont risk it.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 19 Old 01-16-2011, 07:26 AM
storkerlovr's Avatar
yeah you should be fine. you told him to do the right thing. i would add some addatives with lots of lube in them.
95 reg cab 4X4 STROKER
< trade for 5 speed???
new E40D
Autometer gauges
Gearhead tunes
EBP actuator deleted but not gutted
Push button start
TC lock up switch
DIY with 6637
3.5in DP
5in MBRP
315/75/16 M/T ATZ
3:55
smoked lights
herculiner
10inch PRO JL
20%tint
screw all this I just want a 6.4!!!!!!!!!!!!!!
wish list;
5 speed swap
stage 2 injectors
D66
"there may be snow on the mountain but that doesnt mean theirs no fire downstairs
storkerlovr is offline
post #4 of 19 Old 01-16-2011, 08:37 AM
Quoted: 175 Post(s)
Feedback Score: 3 reviews
1/2 a Tank of GASOLINE!!!!
No WAY you should try to run that through the engine....
Drain that tank or you'll pay for it later.
NoRalPh is offline
post #5 of 19 Old 01-16-2011, 10:50 AM Thread Starter
Well I have a 55gal drum that I usually keep bulk oil in for the trucks that is now empty so what about emptying the whole tank into that and filling the last 25 gallons or so with straight diesel and adding 5 gallons every fillup. I really don't want to throw 90 worth of fuel away if I don't have too
445ci is offline
post #6 of 19 Old 01-16-2011, 11:38 AM
Quoted: 175 Post(s)
The problem is that the gas, going through the injectors where fuel is relied on for lubrication, even WITH some additional additives, is going to do damage.
Sure, you could use it up more slowly, but what you're taking about here is like putting a couple of gallons of gas in every tank for some time.... That doesn't sound like a good idea to me
You know the 7.3 wasn't designed to run on ULSD so, without adding something like Opti-Lube with every tank you're already prematurely wearing everything the designers used the fuel to lubricate with the old diesel. Gas just sounds like a recipe for disaster
I'd burn it with my heating oil before I put it back in my truck!
NoRalPh is offline
post #7 of 19 Old 01-16-2011, 03:28 PM
Powerstroke Techie
forddieseldoctor's Avatar
I agree. DON'T TRY TO RUN IT. I saw a 6.4 that had a 25% mix of gas in the diesel and it trashed the high pressure fuel pump and all 8 injectors. I know that the 6.4 has a different fuel system, but it's not worth having to buy a set of injectors or melting a piston or two.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #8 of 19 Old 01-16-2011, 04:01 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
The injectors will hate you for it. No do not do it!
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #9 of 19 Old 01-16-2011, 06:09 PM Thread Starter
Thanks for all the input gents...got the siphon goin overnight putting fresh fuel in the morning...any creative uses for the junk fuel lol
445ci is offline
post #10 of 19 Old 01-16-2011, 06:13 PM
Powerstroke Techie
Bonfire starter. I'm not even sure that I would trust it in a torpedo heater.
Meet Double Aught
2000 F250
