03 F350 6.0 cranking but will not run. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-21-2010, 07:25 PM Thread Starter
Sesco4's Avatar
A boy that I work with has been having some problems with his truck starting. The truck will crank and crank and crank and it sounds like it tries to hit but will not start. Last night it done the same thing and after a couple of hours it finally started. He drove the truck home parked it and it started fine to come back in to work this evening and he started it several times while at work but when time to go home it will not fire. Outside temp is around 40 degrees.
Sesco4 is offline
post #2 of 2 Old 12-22-2010, 04:09 PM
greasltn's Avatar
How long since the last oil change? Do you have access to a good scanner? You may want to check the FICM voltage, if it's getting weak it will not start cold, or it will run rough when it does start.
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
