10K mod problems - Ford Powerstroke Diesel Forum
Old 06-22-2007, 06:45 AM
YEAH BUDDY!
10K mod problems
I performed the 10K mod yesterday on my late '99 PSD. On the test drive it died 4 times. I was told I didn't have a good connection, but the "service engine light" was on. This morning I soldered some wires to the ends of the resistor and re installed it. While it was warming up in the driveway it died. I restarted it, and maybe a minute later it died.
Can anyone tell me what is going on? Am I doing something wrong? I plugged it into the blue/green, grey/red wires.
Old 06-22-2007, 06:47 AM
Fishing Fanatic
I can't remember the color of the wires, but I will look at mine later and let you know. Good luck with it. And If I can help out I will. Let me know
Old 06-22-2007, 06:55 AM
YEAH BUDDY!
Thanks, I appreciate it. It is supposed to be "simple" but for some reason I'm having trouble. I followed the instructions just like the video shows.
Old 06-22-2007, 07:28 AM
Fishing Fanatic
OK I just looked at my truck, and mine is hooked into the Blue wire with green stripe, and the Gray wire with red stripe. So I see that is the same wires you have it hooked to, so?? Where did you get your resistor?? Sure it is the right OHMS and AMP rating?? Hope you get it figured out. Is everything running ok with the resistor not hooked up?? MAKE SURE YOU AREN"T ACCIDENTLY SHORTING THE TWO WIRES WHEN YOU PUSH THE CONN BACK IN. Good luck
Old 06-22-2007, 07:33 AM
It should be at least a 1/2W resistor also. I've read of people having problems if they use a 1/4W...
Old 06-22-2007, 09:06 AM
YEAH BUDDY!
I got them at Radio Shack. They are 1.2watt, 10K OHM resistors.
OOOPPPSS On second inspection they are 10 OHM, not 10K OHM. Must have been in the wrong drawer!!
Old 06-22-2007, 09:08 AM
Fishing Fanatic
That would be a problem Make sure 10K!! I think 1 watt is what mine is, but make sure it at least 10k 1/2 watt. Good luck
Old 06-22-2007, 09:10 AM
The part # from RS for the 10K is:
Model: 271-1126 | Catalog #: 271-1126
Old 06-22-2007, 09:11 AM
I keep hearing about this mod here, what does it entail. Any one have a link to where I can read about this?
Old 06-22-2007, 09:12 AM
i dont mean to steal this thread but what is a 10k mod and wut does it do?
