6.0 Issues - Black Smoke and Hesitation - Ford Powerstroke Diesel Forum
Old 06-18-2007, 09:03 AM
A couple of issues...my 2004 6.0 runs very smooth. Have had no issues. However, when I apply the throttle to pass or power over hills I get a stream of black smoke. It has been mentioned that it may be running rich? Any ideas? Also, I get an intermittent chugging or hesitation on the highway when the engine is put under load. Any ideas comments is appreciated. Many thanks. Alan
Old 06-18-2007, 09:08 AM
try changing your fuel filters, oh and Welcome to the ORG.
Old 06-18-2007, 09:09 AM
Thanks. Have recently changed the filters
Old 06-18-2007, 09:12 AM
sorry bud, someone will be along with more advice, just give it a little time.
Old 06-18-2007, 09:13 AM
is it stock? or do you have intake tuner and exhaust..... as for the black smoke it is normal.... the smoke starts to clear when the turbo builds more boost.... im sure when you going to pass your only at around 5PSI or lower so when you get on it esp if you only do it lightly enough to not down shift you will see plenty of smoke cause their is not enough air going in but once the turbo spools up a bit the smoke clears......
Old 06-18-2007, 09:28 AM
It is stock. Also, at low speed, I hear turbo noise but at higher speeds there does not seem to be much turbo noise. Do you think it is a possible boost issue? Should I buy a programmer?
Old 06-18-2007, 09:38 AM
i don't think the black smoke is anything to worry about... a programmer will only make you make more smoke lol.... it'll be pushing in more fuel for more power.... and intake and exhaust would be a good upgrade... you'll be seeing better MPG with the better flow.. also don't forget your gauges... that way you can monitor your boost and EGT's.... if you want safe reliable power that is an off the shelf item so easy to install the edge Evo programer with the attitude display is a good programmer... here is a link to what it looks like.... i have this on my personal truck....
Edge Products: Product
let me know if i can be any other help to ya...
-Raul
Old 06-18-2007, 09:55 AM
ADMIN AND TECH
dont know how many miles are on the truck, but if its under warranty sounds like egr valve needs cleaning or replaced, if ts not under warranty ,clean valve good and give it a try
Old 06-18-2007, 10:06 AM
Fishing Fanatic
I agree with Scuffy!!!
Old 06-18-2007, 11:34 AM
Many thanks for the feedback. I have a few things to check out.
