2000 7.3 cold start problem! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-23-2010, 03:55 PM Thread Starter
I needs some help bad! 123,600 miles. My 2000 7.3 doesn't run right at idle when its cold and sometimes hot at start up. When the engine is cold I let the glow plug warm up and start it. When it starts either the engine will start loping reel bad and rocking the truck or it will start fine but give it alittle throttle and let off, it start loping again. Also for some reason my rpms will be at about 550 to 600. I dont really notice it to much when its warm but the rpms are still low. It works great other than that. All the fluids are good and at the right level. I have replaced my injector seals, HPOP seals, Fuel pressure reg, fuel filter, CPS and PCM. I do run a older superchip, but it does it even if there no programmer installed. I let it sit over night and checked the oil level in the oil res. on the front of the motor. It was about a half inch from the top. There is no oil leaking anyway on the motor either. I have had it at three different ford dealerships getting work done on it and metioned the problem and could never get any good answers. There are no DTC's and had the mechanic put a data monitor on it and take it for a spin. He said he did see anything wrong. If anyone could give me some advice that would be great.
AlwaysBroken(FORD) is offline
post #2 of 6 Old 09-28-2010, 06:44 AM
greasltn's Avatar
Do a contribution test, you may have bad injectors.
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
post #3 of 6 Old 05-01-2011, 07:10 AM
im havin the same problem with my truck i just bought a 01 f350 C/C LB 4x4 with 320k and it drove fine for about 900 miles and then i started havin problems with my transmission so i took it to a tranny guy and he told me that i have some kinda wiring problem tthe truck was makin his scanner act crazy....so i took it to ford and told them about what the guy told me about the wiring problem and they never gave me a straight answer about it being a wiring problem... they gave me a code print out and i got a few codes and one said injection control pressure sensor circuit low.... my buddie told me its the injection pump... but my dad told me that 99 to 03 7.3 didnt have injection pump it has a heui injection system to where the injectors are there own pump...or somethin like that... is this true or not... these are the codes that showed up.... im young and just getting into diesels... so anything helps thank you very much
P0603 Internal Control Module KAM Error
P0732 Gear Two Ratio Error
P0781 1-2 Shift Malfunction
P1211 ICP Not Controllable - Pressure Abow/Below Desired
P1280 ICP Circuit Out of Range Low
Joshua Cole is offline
post #4 of 6 Old 05-02-2011, 06:07 PM
Sounds like a bad ICP sensor. That's the sensor on the drivers side head behind the alternator it usually has oil in it when it goes bad
Chuck stallions is offline
post #5 of 6 Old 05-02-2011, 07:42 PM
ok cuz I figured it was injectors or somethin..... do u have any ideas about what that internal contol module code might be And one more thing in the mornins my truck shakes and runs rough
until it warms up but if I plug it in it fires right up.... I thought it was
glow plugs so I changed all of them and it does the same thing as before do you have any ideas about what that may be???? Thank u again for time
post #6 of 6 Old 05-21-2011, 07:12 PM
I have 00 crew cab dually with 160,000 on it and a friend also has almost the same truck and mileage, only real difference is I have an auto and he has a six speed. It sounds like we have very similar problem, ours may be worse since we are in MN. So far I have put in new glow plugs, GPR, batteries, battery cables, starter, IPR, ICP, HPOP, valve cover gaskets and wiring harnesses, and injectors. I can get mine to start easily enough as long as it is 50 deg F or above. I have to cycle the key 2x for the full glow plug cycle then I crank the engine until I get white smoke from the tailpipe, then I cycle the key and wait for the WTS light to go off, then it starts. If the truck is plugged in it starts right up no matter how cold it is, but if it 90 deg F I still have to go throught my routine. With gauges installed in both heads and a scan tool hooked up I can see that the minimum cranking speed is met and the ICP indicates approximately the same pressure as the gauges. I have run out of things to check. Any ideas?
Spanker is offline
