6.0 Wont turn over.. starter just clicks (even new starter) - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-15-2010, 10:12 PM Thread Starter
Drove the truck home and parked it, next morning went to start and it just clicks when i turn the key. I charged both batteries and replaced starter/solenoid and still does the same. I have an edge chip as well and shows voltage at 12.1 with now drop when i turn the key! PLease help!
aspenboarder is offline
post #2 of 10 Old 09-16-2010, 04:13 AM
greasltn's Avatar
Double check the connections to the battery and the starter. You didn't get an advance auto starter did you?
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
post #3 of 10 Old 09-16-2010, 05:39 AM Thread Starter
no its a napa starter and all the connections are secure
post #4 of 10 Old 09-16-2010, 05:46 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 29 Post(s)
Feedback Score: 4 reviews
Try and disconnect your Edge, and see what it does, for S&G's
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #5 of 10 Old 09-16-2010, 06:42 AM
tekemp's Avatar
it could still be your batteries but its hard to know without testing them unless you have a way of getting a hold of a tester that will load them and test the CCA.
2012 F-350 CCLB XLT/EGR/WEATHERTECH/RIGID/CTS/
tekemp is offline
post #6 of 10 Old 09-16-2010, 09:28 AM Thread Starter
Batteries are good, (i believe), I put a jumper box on each battery and it still it doesn't even turn (not even a little bit)
post #7 of 10 Old 09-16-2010, 02:07 PM
Powerstroke Techie
Disconnect the cooling fan clutch and try it again. When the fan clutch shorts out it won't let it crank.
Also, near the blower motor at the passenger side of the engine compartment is a single wire connector,(i believe the wire is green and yellow). You can disconnect it and touch it to the bolt on the positive battery terminal. This will rule out the rest of the wiring because from this connector the wire goes straight to the starter solenoid. If it cranks, then suspect the transmission range sensor or fan clutch.
I've seen many fan clutches cause this concern so this would be my first guess.
MotorCrafter3208 is offline
post #8 of 10 Old 09-16-2010, 02:43 PM Thread Starter
I will try that.. dont know what i did.. but now my Starter fuse is blowing. What should i look for that would cause that
post #9 of 10 Old 09-16-2010, 04:10 PM
Send a message via Yahoo to tony323
test voltage at the starter with a dmm, sounds like you have a short somewhere in the system. I've jumped a few starters but do so at your own risk.
tony323 is offline
post #10 of 10 Old 09-17-2010, 04:20 AM
greasltn's Avatar
Try to locate the clicking sound. Is it a relay, solenoid, or the starter itself? I'm hoping you didn't hydro-lock the engine.
-John
greasltn is offline
