PCM - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-21-2010, 03:20 AM Thread Starter
PCM
how common is it for pcm to go bad
has anyone had experiance with this
how do you test to see if pcm is bad
tecelec1 is offline
post #2 of 7 Old 07-21-2010, 06:54 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Whoa,,, Dude, talk about a lack of information....
What year?
What engine?
What's it doing?
Yes a PCM can fail, but just as likely it could also be a fuse supplying the PCM.
NoRalPh is online now
post #3 of 7 Old 07-22-2010, 11:43 AM Thread Starter
What year?
What engine?
What's it doing?
2002 F350 7.3
will a pcm from 2K F250 7.3 work in a 2002 f350 7.3?
tecelec1 is offline
post #4 of 7 Old 07-22-2010, 01:53 PM
Quoted: 133 Post(s)
When you first roll the key ON - Do you have a WTS (Wait To Start) light?
Have you Double Checked fuse 30?
There is a sticker on the PCM itself (you'll have to remove it) with a specific number that has to be matched or cross referenced. You have to match the options of the truck (trans, 2/4WD, etc) for it to work I think.....
post #5 of 7 Old 07-22-2010, 05:01 PM Thread Starter
yes i have a wait to start light, and yes fuse 30 is good
dont know if you have background on problem so here goes
new icp sensor, cleaned ipr, fuel good, pressure 65psi, idles smooth,new cps,
ebpv open, turbo pressure good,wiring checks out
problem is no power from idle on up, truck will run up to 75
injection pressure runs up to 2200psi when you drive it
it does not seem like a fuel problem, but it seems like turbo is not boosting
do not have a boost guage so i cant check running boost pressure
will truck run if pcm is bad?
any ideas?
oh and thanks for your input and help it is greatly appreciated
tecelec1 is offline
post #6 of 7 Old 07-22-2010, 05:24 PM
Quoted: 133 Post(s)
If the PCM was dead (and in most cases, complex electronics like a PCM either work or don't work) it wouldn't run at all. The WTS is another sign that the PCM is Not dead.
The next PCM problem could be that it would benefit from a reflash but, you'd need to go to the dealership for that
Is the truck stock? Do you have a chip in there?
Can you hear anything from the turbo? You should be able to hear it whistle, especially over 2K-rpm going up a hill with your foot "in-it"...
How about a boost leak in the plumbing to and from the IC?
Do you have a lot of miles on it? Maybe a compression test?
post #7 of 7 Old 07-23-2010, 04:09 AM Thread Starter
no chip, if you take the boot from air cleaner off and put your hand across the intake it will almost suck your hand in it, 165k on truck, problem arose in about a weeks time gradually so i dont think it is compression ill check plumbing system
thanks
tecelec1 is offline
