Diagnostic trouble code 1280 - Ford Powerstroke Diesel Forum
Old 05-20-2007, 07:09 PM
YEAH BUDDY!
Arrow Diagnostic trouble code 1280
I have a late '99 PSD, and my "SERVICE ENGINE SOON" light has been comming on at initial start up. I let my rig warm up for at least 10 minutes before I pull out. When I pull away, I don't notice a loss in power but as I get about 1/2 mile from the house it "the light" goes out, and she just surges obviously back to full power. I ran a test today with my EDGE EVOLUTION and it pulled the code: P1280: INJECT. CONTROL PRESSURE CIRCUIT OUT OF RANGE LOW.
CAN ANYONE TELL ME WHAT THIS MEANS?
Thanks !!!
Just turned 218,500 miles!
Old 05-20-2007, 07:23 PM
Thats Mr. Oil Leak.....
Could mean the ICP sensor is going bad.
Old 05-20-2007, 09:13 PM
YEAH BUDDY!
Um....you have to remember I'm a "gas guy" what is an ICP sensor?
Old 05-21-2007, 06:29 AM
Is it even worth it???
ICP is Injector Control Pressure. That is the sensor that measures the oil pressure and controls what the HPOP (High Pressure Oil Pump) does.
Like John said, I think I'd start with the sensor, and work from there... That's a whole lot cheaper than a new HPOP!!
Old 05-21-2007, 06:37 AM
ADMIN AND TECH
defintily would try that first , most of the time 1280 is sensor or wiring to sensor
Old 05-25-2007, 06:57 PM
Could also be the IPR sticking from the wrong weight of oil & maybe it needs changing.
Old 05-25-2007, 07:42 PM
YEAH BUDDY!
Im using Chevron Dello, 15/40 and just changed it about a month ago. Just checked it today during a fill up and it looks good.
I found out the ICP from the local dealer is about 750.00!
Old 05-26-2007, 06:09 AM
That sound to me like your getting ripped off. Are you talking about the IPR maybe. It is a bit higher than the ICP sensor. It would be better if you could get ahold of a scanner & get those codes. I/m sure there has to be at least some continuous codes if not some hard fault codes. If thet lits comes on there will surely be some hard fault codes set & that would make it easier to diog.
Old 05-26-2007, 10:32 AM
YEAH BUDDY!
Should I just take it to the dealer and have them run a hard code scan?
Old 05-26-2007, 09:54 PM
ONE! icp sensor I had quoted to me yesterday is $175 at the ford garage so who ever quoted you 750 got something screwed up a new hpop is around 750 bucks so I would def go some where else or talk to a difrent parts guy if it was at the dealership. my truck has pulled the same code and im trying to get it fingered out.
