6.4L blowing out radiator - Ford Powerstroke Diesel Forum
Old 05-12-2007, 06:56 AM
I assume i'm at the correct forum location for these 6.4L's. Redirect me moderators if i'm not. This 08 F350 has blown out 2 radiators & International is most likely coming out next week to investigate. Has alot of water & oil deposits in the intercooler. They told me to check the fitting going from the frt. cover to the heater core for restriction. Customer did state that it got hot on the 2nd time in but not on the 1st trip in. Only set a egr cooler temp low voltage code from coolant system getting very low on coolant & not cooling egr properly. Tested radiator cap & does vent properly. wondering if anyone has run across an concern for this. The eng. runs normal w/ no smoking. no missfires or codes this time in, just a P1000 from the last time he was in which was less than a week. Customer is very mad & has contacted ford about this concern.Any info would be helpful.thought i would get a jump on this before international came out. I have all the freeze frame data recorded for this.
Old 05-12-2007, 06:58 AM
International Threat
Yup, you're in the right forum! Welcome to the site. Sorry I do not know much about the 6.4 and couldn't even begin to diagnose the problem lol!!!
Hope Marc, Stroketech or scuffy will see this... maybe one of them will know!
Old 05-12-2007, 07:03 AM
Thanks for the quick response Maintain.I am a master certified diesel tech but this is my first 6.4L w/ a concern. have done alot of reflashes for the flames coming out the exh.
Old 05-12-2007, 08:12 AM
ADMIN AND TECH
i have not seen this concern , did have a upper radiator hose blow off , thought might have a high coolant pressure problem , but turns out a new hose fixed the problem , would like to hear what ends up taking care of your concern , sorry cant help
Old 05-12-2007, 01:28 PM
Strokin' In Dixie-Land
Seems like I read an article about these 6.4's having high volume water pumps. Maybe something to do with this???
Old 05-13-2007, 12:43 AM
how often do you get these reflashes coming in.... and i was curious do the reflash really detune and low the hp or is that a rumor
Old 05-13-2007, 08:49 AM
were you pertaining to your 2001 trk.? i was pertaining to the 6.4L's. the reflashes for your trk. has diminished some what. the only time i reflash one of the earlier models is when one comes in w/ a chip or programmer & they want be to reflash it back to its original configurations. the 6.4L's. have only one so far for the flames shooting out the exh.
Old 05-13-2007, 03:35 PM
i was referring to the 6.4 ..... when you reflash it was exhactly is it doin... it is toneing down the hp or... what.... and is there any succeful way to take off the particulate filter with out getting codes
Old 05-14-2007, 04:41 AM
It has something to do w/ the fuel strategy & timing lowing the fuel pressure during the particulate filter cleaning stratigy. I'll have to do some more research though. It has something to do w/ fuel control, that much i do know.
Old 05-14-2007, 01:18 PM
On this site all of us have heard A LOT of HEAR-SAY about the 6.4. You say this is your first one with concern???
