6.0L wont start, but cranks.. need help asap
New to the site!
Went out to start my truck(04 6.0L powerstroke) today after sitting all night and it would crank over but no start, it stuttered just a few times after cranking it a few times but batteries were starting to go low so i quit. I last drove it yesterday on a trip and ran fine no problems at all. When i got back to town i was low on fuel so i filled it up with #2 and came home and parked it. Just wondering if it is too early to run straight 2 with no addititive, its high 30's during the day here and mid 20's at night! need help as this is my only viechle... just had truck in dealer for new head gaskets, studs, egr valve, oil cooler tank, improved turbo drain pipe, and egr cooler, more or less a good chunk of change.. starting to less and less like the 6.0 haha, thanks for the help |
04moneypit, did you find out what was wrong? was it the fuel?. I'm having the same exact problem. Turns over but will not start. by the way great name, it says all. mine is an 03
plug it in and see if that helps but mine did the same thing and it was my ficm but it is too expensive to just buy parts there is a way to test your ficm but I dont have the diagram to give ya I know it is on here somewhere though good luck
you should defiantly be running a additive. you fuel is probably jelled up
Yes i figured out what my problem was.. It was my ficm module, cost me about 900 bucks to get fixed with some connections.. haha, i had to replace old one and then you have to get the new one programmed to your truck which isnt included in the price of the module, stupid i know.. but that cured the problem right up.. havent had problems since
yep they get ya I got a deal on mine and it was 700 from ford glad ya got it goin
