2000 7.3l No Crank - Ford Powerstroke Diesel Forum
Old 03-04-2010, 07:52 AM
Send a message via AIM to Shaolin Crane
2000 7.3l No Crank
2000 7.3l No crank so obviously no start, i can hear the fuel pump or heater under the hood working, but turn the key and nothing, WTS light comes on then flickers slowly off, help is appreciated
Not the truck in my sig
Last edited by Shaolin Crane; 03-04-2010 at 07:53 AM. Reason: BTW not the truck in the sig
Old 03-04-2010, 07:53 AM
Does the tach move when you are cranking the truck?
Old 03-04-2010, 07:54 AM
Edit nvm....the truck won't even crank...........
Old 03-04-2010, 07:55 AM
May sound like a dumb question but are the batteries good and charged
they are pretty old so that could be it, but it was shut off then wouldnt start soon afterwards
Old 03-04-2010, 08:51 AM
ok jumped the posts on the solenoid and it cranks, pulled some of the connectors of the hpop and still wont start, what next?
Old 03-04-2010, 09:09 AM
hook up a test light to the negative post of your bat and remove the red signal wire on the starter solenoid located on the fender. If there is no power to the signal wire with the key turned on then check fuse #20 located under the dash on your fuse panel. Replace if burnt out and should start up.
