PUKED ANTI-FREEze after water pump change - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-23-2010, 05:30 PM Thread Starter
Angry PUKED ANTI-FREEze after water pump change
Long story short... I am traveling in MICHIgan. The other day, I parked, anti-freeze leaking.. steady drip. Finally overheated.
I had some guy I found here, and he changed my water pump and thermostat. I drove to Cleveland, then back to Michigan the next morning. 350 miles total. Everything fine.
Drove this afternoon about 20 miles, everything fine. Then I came out 4 hours later, and all my anti-freeze is on the ground!!!
It is dripping from a bottom hole in the radiator. Not from the engine block and not sprayed all over the inside of the engine. I'm not familiar with radiators. The overflow resevoir is full! completely full. Its dark and I'm standed, cannot see if there is any in radiator but i doubt it. Its all over the pavement.
ANyone know what to look at? Its coming straight from the hole in the bottom of the radiator. Its not a "hole" as a hole in the radiator, its a hole that is supposed to be there. Please help, I do not know any mechanics here and I have to get back to cleveland. What should I do? Could it be a hose? If it was another bad waterpump they put on how do I know?
Natedog4500 is offline
post #2 of 3 Old 02-23-2010, 05:42 PM
JER-1's Avatar
Quoted: 17 Post(s)
Cool
Man sorry for your bad luck, by any chance it's not a drain plug opened up that was maybe loose or not tighten up proper.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #3 of 3 Old 02-24-2010, 03:33 PM Thread Starter
tHanks
And the answer is..... RAdiator. Turns out it has rotted away. Guessing thats what caused my water pump to crap out. ANyway, got one put in today. Thank you so much!!
