Oil Everywhere - Need Help - Ford Powerstroke Diesel Forum
Old 02-19-2010, 03:22 AM
Angry Oil Everywhere - Need Help
So I finally got enough money to change from Delo 15w 40 to 5w 40. Got it done yesterday. Got up this morning an there is 1/3 of a qt under my truck. Drove to work and with 15 min there is another 1/3 qt under my truck. Did some looking around and it seems like it is coming from all the way around were my tranny meets my block. Top, bottom, everywhere. I know with a lighter weight oil its easier for it to find places to leak but this is bad. Plus I just spent $150.00 on oil hoping for better not worse. I am not overly familiar with the block / transmission area. Any help or ideas would be appreciated. I don't have enough money to run her into the shop.
Old 02-19-2010, 03:26 AM
Tennessee Powerstrokes
I don't really have a clue but here is a to keep it active for ya.
Old 02-19-2010, 05:21 AM
So I did some more lookin and it seems to be coming from where me bell housing meets the block. I am not sure what is above the bell housing but that seems to be the point of origin. Thanks in advance guys.
Old 02-19-2010, 05:26 AM
<-Day Of Fail now SOLD
On the back of the valley there are two weep hole for any fluid to run down the back of the block and bell housing.
Old 02-19-2010, 05:31 AM
Would that amount of oil consistantly come out of those weep holes? If so what would cause it? I didn't overfill it.
Old 02-19-2010, 05:32 AM
Unapologetically American
Feedback Score: 4 reviews
The ICP sensor is a common leaker on the 6.0 (I think that's the sensor). Its under the turbo somewhere from what I have read, but it could probably be 10 other things too
Old 02-19-2010, 05:33 AM
I think several people say check the turbo lines and 0-ring.
Old 02-19-2010, 05:41 AM
anything leaking on the top of the motor will run down the back of the motor. Oil Filter housing, turbo feed line, turbo return, or ICP.
Old 02-19-2010, 06:00 AM
New developments - Not the filter housing. Can't see any oil from the top of the engine. It is definitely coming from above the bell housing. I also have either coolant or oil coming out of the exhaust pipe. I can't tell which it is. Does that mean EGR?
Old 02-19-2010, 06:14 AM
Found oil on top of the motor. If you were to look down from above it is between the filter housing and turbo. Turbo line is fine and dry, filter housing is fine and dry. EGR? Oil cooler?
