6.0 won't start after cold temps - Ford Powerstroke Diesel Forum
Old 02-15-2010, 06:32 PM
I left my 6.0L powerstroke out in the North Dakota winter for 3 days. Temps weren't too bad...around 15 below at the coldest. Plugged in the engine block heater for 24 hours. Still wouldn't start. Pushed it in my garage this morning where it is around 55 degrees. Been in the garage all day with the engine block heater plugged in. The engine just spins! Tries to fire every once and a while, but won't take off. Put some Emergency 911 de-gell supplement in it, still nothing. Need to get to work in the morning with this truck. Truck ran perfect before this. Never had to have it plugged in more than a couple of hours before this. Any suggestions welcome. Thanks.
Old 02-16-2010, 03:48 AM
Have you pulled your fuel filters to see if they are gelled up?
Old 02-16-2010, 03:50 AM
scuffs *****
Send a message via AIM to Tyler
You need to get a scan tool to pull codes and readings while cranking.
Is it smoking while trying to start? Sounds like the FICM is pooped.
