Truck just died while driving... please help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-15-2010, 08:32 AM Thread Starter
I was driving back from jewel yestorday with flowers for my gf and my truck just died, check engine light came on stating water in fuel, first thing i did was pulled over to the side. I grabbed the manual and the second thing i did was drained the water from the bowl. I tried starting the truck again and it wont start. No check engine lights are on now. What should i do? 99 Ford F350 266k Miles
dj2kewl4upl is offline
post #2 of 6 Old 02-15-2010, 08:33 AM Thread Starter
I have the 99 7.3litre F350
post #3 of 6 Old 02-15-2010, 08:35 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
Originally Posted by dj2kewl4upl View Post
I was driving back from jewel yestorday with flowers for my gf and my truck just died, check engine light came on stating water in fuel, first thing i did was pulled over to the side. I grabbed the manual and the first thing i did was drained the water from the bowl. I tried starting the truck again and it wont start. No check engine lights are on now. What should i do?
What kind of truck do you have??? Year, model, engine, mods....can't help diagnose it without knowing what it is
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #4 of 6 Old 02-15-2010, 10:15 AM
greasltn's Avatar
Did you cycle the key a few times to purge the air from the fuel lines?
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
post #5 of 6 Old 02-15-2010, 10:24 AM
cpayne6335's Avatar
Fuel filter might be clogged up? when was the last time you changed it?
Looking for a FORD.
Chris
US Army, MOS:88M Ft. Lewis 17th Fires
cpayne6335 is offline
post #6 of 6 Old 02-15-2010, 10:32 AM Thread Starter
well fixed it guys, it ended up being a clogged fuel filter, changed it, purged the lines, and walllaaaa gurgurgurgurgur she went!
Thanks for the help
