rkc1020 6.0 L 2004 replaced oil cooler/ no start
Hi Guy's, I had a so called mechanic replace the oil cooler in my 2004 F250 sd
and now he started it with a shot of starting fluid but it won't start at all now and I don't know what I should check out 1st. I did find the plastic connector for the fuel injector lock was broken. The truck started and ran fine before he worked on it. Thanks for any help. |
to the ORG!! Hang in there tech help can be a little slow on the weekends as people tend to not get on here as much. I will move this to a more visable location for you.
There was a truck at my shop that did the same thing after replacing the oil cooler and egrv. It turned out that the Injector Pressure Regulator was clogged up. Replaced and started w/o any problems.
