Engine Sputters and Shuts Off - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-09-2010, 09:39 PM Thread Starter
Exclamation Engine Sputters and Shuts Off
2001 F250
- Truck died, 30A fuse for PCM / Fuel Heater / IDM relay blows when I turn the key forward.
- I have unplugged the fuel heater and replaced the fuse. The truck does not start, it just cranks over.
- I can not even pull start the truck (it’s a manual)
- The WTS light illuminates on the dash.
- All fuses are now intact.
- Batteries are hooked up to a charger
- RPM's register when cranking and I replaced the CPS
- Truck starts without ICP sensor plugged in.
- Replaced ICP and does the same thing.
Thanks
Justin
wildchild is offline
post #2 of 11 Old 02-09-2010, 09:53 PM
International Threat
Marty's Avatar
7.3's only need fuel pressure, oil pressure, Power with electrical continuity and air to run. Go ahead and scratch air off the list since I'm sure you are getting that.
The first and easiest way to diagnose (always the best place to start) is with a FORD scanner, Auto Enginuity, Snap-On brick scanner, etc... You need to have a scanner that actually WORKS on Ford Powerstroke Diesels in order to get these readings. Here are a few items you should get off the scanner. Codes, are there any? Is there an SES (Service engine soon, check engine light) on when it's idling? If there are no codes then you should perform a Buzz test to double check good connection with the injectors. This could identify if you have an issue with your UVCH, Electrical wiring on the motor or IDM. If you pass those tests then you need to check ICP and the IPR duty cycle. When cranking on the truck you should watch your ICP quickly jump from 0 psi to 15, 100, 250, 400+ psi and once it goes past 400 psi it should start. Meanwhile your IPR should be ramping up in a similarly quick fashion while cranking. You should see 9 - 14 volts with the key on depending upon the condition of the IPR. It should ramp up from 14 to 20, 25, 30, 32 etc... and level out around <35 psi in order to start. If it ramps up to 65, 75, 85 etc, there is another issue at hand. Watch your ICP/IPR while idling. ICP should stay around 500-700 psi and IPR should stay around 9-14v. Finally if all that passes, we need to know what your fuel pressure is when you turn your key on, while you're cranking and once it is started. The truck may start and sputter if you're getting 20 psi or less... but most likely this isn't your problem. I have seen trucks with dead pumps get started and then the injectors siphoned enough fuel to stay running even though the gauge showed 0 psi of fuel pressure.
I hope this has helped you. The results of these tests will diagnose probably 97% of the problems on a powerstroke.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 11 Old 02-10-2010, 07:18 AM
If the 30A fuel heater (and other stuff) fuse blew, then you probably have a short in the fuel heater. I am not sure if it is related to the other problem, but you may want to unplug the fuel heater from the fuel bowl till you get it fixed, replaced, or deleted.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #4 of 11 Old 02-10-2010, 01:52 PM Thread Starter
Well I changed my batteries andoil sensor on top of hpop truck start and runs fine again for now anyway ???? Waiting on a guy to come out to check fuel pressure and oil pressure tonight.
The ses light has only came on when the icp sensor was unplugged and went out when plugged back in
Thanks everyone
Justin
Last edited by wildchild; 02-10-2010 at 02:39 PM. Reason: Forgot to mention ses light
post #5 of 11 Old 02-10-2010, 02:15 PM Thread Starter
Question
the fuel bowl heater you said possibly delete would that be a good option even if you worked nation wide? If so is there a kit or do you mean just leave unplugged ?
post #6 of 11 Old 02-10-2010, 05:21 PM Thread Starter
Had a mechanic come by no codes exeption the ones I caused myself.
Had to pull plug on icp sensor to get it started.
Changed out the cps again.
He didn't bring guages to check oil and fuel pressures.
Truck seems to run fine intermitantly.
Sometimes it starts easy sometimes not.
The only thing we could find is oil seeping through icp sensor.
Dried icp plug restarted truck plug became wetter with oil
he said the only thing he could figure is the new icp sensor is bad because of it seeping oil out the top.
I will be taking icp back to ford tommorow for an exchange .
Hope that's all it is
thanks
Justin
post #7 of 11 Old 02-13-2010, 01:33 PM
Marty's Avatar
Yes, if the ICP sensor is seeping oil then it is not good.
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #8 of 11 Old 02-18-2010, 05:23 PM Thread Starter
update!!!!!!
sorry it took so long but i had to leave town for work
had to have my truck towed to a dealer they say they have worked on it for thee days and still dont know whats wrong feul pressure is good
oil pressure is good and they are telling me that they think all 8 injectors are bad (quote) gaulded ??? and they want to charge me $4500 to replace all 8 injectors but cant guarentee that will work and $400 for a compression check
and i may need a new motor for $10000 dollars
i already owe $300 for nothing
thanks
justin
post #9 of 11 Old 02-18-2010, 05:29 PM
no-tel-in's Avatar
first, run from the dealer, get ahold of a Scanner ie:autoengunity
Log the results while cranking and post em up!
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #10 of 11 Old 02-18-2010, 05:34 PM Thread Starter
i had it on a scanner for two hours last week no codes everything looked normal unless i unplugged a sensor and caused a code truck would not mess up while i had a mechanic at my house he had a snap on machine
