I have a 2002 f250 with the 7.3 I bought and install a wicked wheel. while the turbo was out I bought a blank pedestal and a Non-EBV Outlet Flange. I finished last night and was taking her out and heard what sounded like a blow off valve and now i have have no or very little boost. When I stopped i opened the hood and there was a little smoke. No oil leaks... I checked and rechecked all the exhaust fittings... no leaks........ How do i know if the turbo is getting oil? When I put in the blank pedestal do i need to do anything with the old ebv sensor wire?? Wastegate???
HELP!!! Thanks in advance..
did you check your intercooler boots?
SWEET!!! Thanks dude. I cant believe i over looked that i was in a hurry i guess. I am still kinda new to this PSD thing.
was that the problem then? if you haven't fixed it already you might look into doing a CCV filter or reroute, and new intercooler boots from dieselsite, they are a pretty good upgrade over stock, and the crankcase vent filter or mod will keep oil from saturating the boots, which can cause boots to blow.
yeah that was the problem. I will def look into some new boots. Thanks again.
