Broken Glow Plug - Picture Attached HELP !!! Thank you - Ford Powerstroke Diesel Forum
Old 02-08-2010, 07:36 PM
Evening, Have a 96 F250 7.3L with about 250,000 miles on it that after driving it to Chicago this past Christmas wouldn't start when cold. After advising with a few shops I was told that I should replace all the glow plugs along with the relay while I was at it. All was going great until I came to the last plug. The top portion came out but left the bottom half along with a small portion stuck in the hole. I am guessing that due to carbon build up it is why it is stuck? I am still able to grab the portion sticking up but VERY NERVOUS that if I continue to play with it that I may either damage the hole or drop the stuck plug into the engine. Any advise on how to proceed would be a great help. Is there any magic trick to pull out the portion that is still in the engine... any special anti-carbon spray, or tool to remove this? If I do have to take it to a shop what should I expect to pay ? Ya'll all are great, thank you for taking a little of your time to help guide me.
Attached is a picture of what happen and circled in red to the portion that is sticking out.
Old 02-08-2010, 07:46 PM
Shade tree mechanic
I have been here before... I have had two plugs stuck at once. One of them I got out by spraying oven degeaser on it. Let soak for 5 mins and pulled it out with a pair of needle noses. The second one there was no such luck and I had to pull the head and retieve it that way. Good luck. Keep us posted.
Old 02-08-2010, 07:50 PM
Thank you !!, will give a try with the oven degreaser tomorrow. If the unthinkable happens how hard would it be for a novice to pull the head ?
Old 02-08-2010, 07:58 PM
Shade tree mechanic
Since you are already into it this far, pulling the head wont be too bad at all. Make sure you buy a good quality Oven soaking agent. Spend the extra few bucks and get the good stuff.
Old 02-08-2010, 08:00 PM
Shade tree mechanic
oh, and I used a set of needle nosed that had the extra bend on the the head of the pliers....seemed to help when trying to fish around down there.
Right on, thank you once again ! Will post tomorrow evening how it all turned out.
Old 02-08-2010, 10:00 PM
You might also try aerokroil that stuff is awsome it penetrates great and has a low flash point
