Need help bad!!!!!! - Ford Powerstroke Diesel Forum
Closed Thread
Old 02-07-2010, 10:58 AM
Exclamation Need help bad!!!!!!
I have an 01 f250 truck died won't start the 30a Pcm relay coil, fuel heater, wastegate solenoid,injector driver module relay coil fuse blows when I turn the key on I got to get this fixed asap or I'm gonna lose my job !!!
Any help will be appreciated thanks
justin
Old 02-07-2010, 11:35 AM
Try unplugging your fuel heater, then replace the fuse. most time when this happens your fuel heater is shorted to ground.
Old 02-07-2010, 11:42 AM
Yea. Just unplug the fuel heater plug on the back of the bowl. Then replace the fuse and you'll be good to go.
Old 02-07-2010, 12:41 PM
I did that now it won't start even tried pull starting when pulling it will run but won't start it s really getting me mad
Old 02-07-2010, 12:42 PM
You sure you unplugged the bowl heater and replaced the fuse?
Or does the fuse keep blowing?
Old 02-07-2010, 12:47 PM
Real Men Love Jesus! <><
does the wait to start light come on? if not, the PCM is not getting power.....
Old 02-07-2010, 12:51 PM
I pulled the plug at the back of the fuel bowl and yes the wait to start light does come on it just cranks and cranks no start now
Old 02-07-2010, 02:34 PM
Does anyone know if it could have shorted out my computer
Old 02-07-2010, 02:36 PM
It might've but that's what the fuse is for. You SURE the fuse isn't blown again?
Old 02-07-2010, 02:37 PM
shaking things up
check the fuse again then look when you are cranking do the rpms register? if not repalace your cps
Closed Thread
