Boost leak - Ford Powerstroke Diesel Forum
Old 04-09-2007, 05:46 PM
JJR JJR is offline
Boost leak
I have a early 99 that leaks its boost. It only does it when the engine is warming up and at part throttle. Once it is at operating temp it is fine. I can hear a hissing noise when it does it and the boost gauge drops. I suspect something with the engine back pressure valve any thoughts.
Old 04-09-2007, 05:49 PM
Desert Shield/Storm Vet
Yeah sounds like your ebpv is sticking not letting you build boost. I had the same problem and unplugged the solenoid to the actuator before I gutted it.
Old 04-14-2007, 05:25 AM
JJR JJR is offline
Unplugging it seemed to fix it. Thanks
