STALLS AND DIES OUR WHEN COLD - Ford Powerstroke Diesel Forum
post #1 of 1 Old 01-24-2010, 08:09 AM Thread Starter
SNOWKING89's Avatar
OK HERES THE THING. WHEN I START MY 96 AND IT IS COLD IT WILL SIT AND IDLE FINE BUT AS SOON AS U START DRIVING IT STARTS TO SPUTTERIN AND BURPS... IT WILL DIE OUT AND CEL COMES ON BUT AS SOON AS U SHUT THE KEY OFF IT CLEARS THE CEL AND THEN ONCE YOU CRANK IT FORA LITTLE BIT IT WILL RESTART BUT BURNS A TON OF OIL AND RUNS ROUGH..... AND WHEN IT IS RUNNIN FINE IT MAKES THE WEIRDEST NOISE NOW I NO UR GUNNA CALL ME CRAZY BUT WHEN IM COASTING OR BRAKING IT SOUNDS LIKE THE TURBO IS SUCKING IN AIR FROM THE EXHAUST???????? WTF I NO SOUNDS CRAZY.....
OK I GOT SO MANY TURCKS HERE ARE MY TOP TOP THREE THAT GET USED DAILY.
08 F-350 SD CC 6.4 ALL I HAVE TO SAY IS SEXY
97 F-250 7.3 DIT Crew Cad Short Bed... Woot
95 RAM 2500 DUALLY CONVERSION CUMMINS 5 SPEED R.I.P. donezo
SNOWKING89 is offline
