Truck caught fire!!!
Well went out to start my truck this morning, turned key and smoke started coming from under the hood and dash vents, popped hood and top of engine was in flames, hpop hose, glow plug relay and engine valley was all in flames, anybody now wat might have caused this???
thanks for the reply not sure if thats wat caused mine will look and see though
wow that sucks how bad is the damage?
there was a recall on the overdrive button or somethin like that, but it caused the trucks to catch on fire... im not to sure if that was it but it might be worth lookin into.
i think that was on the gas jobs
got any pix?
the diesels had the recall 2, just took mine in today to get it done
no this is not from brake switch recall will get pics in morning, but there is white stuff all over the HPOL not sure if a chemical reaction caused it during the fire, but the only damage i see is needs new hpop line, and fix burnt wire, looks to me like the yellow wire from the glow plug relay may have been rubbing on the oil line and just wore through the insulation and the hot wire burnt through the oil line when i turned the key on and ignited the oil,
holy jesus atleast you didn't have some sort of explosion. sit down in the truck with a cup of coffee turn the key and blow the hood of not to mention fill your drawers. crazy man hope you find the answer would put many at ease to figure out what it was. Atleast you're alright tho.
