A little help please - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-16-2010, 12:55 PM Thread Starter
Hey i got an 06 f-350 dually 6.0 it runs like crap.Cranks up fine but smokes white.Shakes pretty bad while driving and low power.I got codes p0269, p0278,p0284.
superdutyflatbed is offline
post #2 of 8 Old 01-16-2010, 02:09 PM
FX4 F2-Fifty's Avatar
Found this in the tech section
"P0261-P0284 = = = = INJECTOR TEST (NEED A SCANNER FOR THIS)."
2004 F250 CC Lariat SB FX4
ARP Studs
Modified S300
Elite 205's
EGR MIA
Elite Stage 2 Fuel
ZEX Nitrous
Airaid Intake
Accufab Elbow
Autometer Gauges
Magnaflow SS Exhaust
Innovative Tunes
20" Chrome RBP 92r
FX4 F2-Fifty is offline
post #3 of 8 Old 01-16-2010, 08:07 PM Thread Starter
I have access to a scanner
post #4 of 8 Old 01-16-2010, 08:20 PM
thesmokinstroke02's Avatar
test your injectors and see if theyre all runnin right
Konnor
2011 Cruze
R.I.P. Will Iott
thesmokinstroke02 is offline
post #5 of 8 Old 01-16-2010, 09:22 PM Thread Starter
I did a buzz test and it didnt return any codes.What other kind of tests can you do?
post #6 of 8 Old 01-17-2010, 05:00 AM
greasltn's Avatar
On a buzz test you listen for the sound, not look for codes. You also need to do a contribution test.
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
post #7 of 8 Old 01-17-2010, 06:08 AM
I got a 1999 F350 and it would run real rough on idle and smoke white until it warmed up and then ran fine. The colder it was the worse it got. I had my buddy who works a a local Ford Dealership come over and checked it out and I had 3 injectors on the drivers side going south. I also had 240,000 miles on this truck. He replaced all 4 injectors and glow plugs on the drivers side and all is well now.He does alot of side work for alot less than the Dealership charges.4 new Ford injectors and glow plugs $1500 and labor $200. This hurt since I am unemployed at this time, but I need the truck since I am going to school full time for HVAC.
Charles Murphy
Bessemer City NC
1999 F-350 Crew Cab 4x4
BTS Transmission BTS Tune Issopro Gauges
MBRP 4 inch Turbo Back Exhaust K&N FIPK Air Intake
reddgz is offline
post #8 of 8 Old 01-17-2010, 07:39 AM Thread Starter
With the snap on scanner when the buzz test is finished it says no codes found which i guess it means all the electrical part to the injector is good
