a full tank of GAS in a 06 f355 6.0 - Ford Powerstroke Diesel Forum
Old 01-13-2010, 05:58 PM
Help, I'm sitting on the side of the road right now.
I am real tired and realy sick, i stopped to fill up at shell, tthe bronze gas pump handle was yellow or so it looked in the light, (has a very strong hps lamps above) anyway, i put 125 liters in the tank, tank hold 142 i think. drove 5.6km 4 miles and the truck started running like ****. i pulled over and shut it off and looked at my recipet.
I got a buddy on his way with new diesel (150liters) and a pump and siphion to empty the tank into another tank.
What is my best course of action?
how do i purge the gas safely?
how do i drain the system?
should i tow it?
Old 01-13-2010, 06:28 PM
Have someway to get all the gas out. Open the water drain and run the pump until diesel comes out I would think
Old 01-13-2010, 06:31 PM
if gas got to the engine your gonna have to replace some injectors. IF it didnt, just drain it out and put diesel back in it.
Good luck man
Old 01-13-2010, 06:57 PM
Powerstroke Techie
You might be okay on the injectors. Drain that **** outta there and put some GOOD clean fuel in it. PUt a whole jug of that PM-23-A Cetane boost an performance improver in the tank.
I had an econoline once that had been filled from 1/4 tank to full with gasoline, then driven from full to about half and it didn't IMMEDIATELY need injectors.
Disconnect the fuel line after the pump, run the fuel pump with a hose on it till the tank is dry.
Best way would be pulling the tank and washing it.
Change the fuel filters.
Pray.
Old 01-13-2010, 07:02 PM
i would tow it an have someone look at it to make sure all that gas is out of there if not you could ruin the motor dont take the chance of driving it
Old 01-13-2010, 07:06 PM
Send a message via AIM to pistolpete837
get it towed, thats cheaper than injectors
Old 01-14-2010, 02:24 PM
got her running
I called my cousin, said to drain and replace the fuel and ad 2 stroke oil to the fuil and drain the fuel filters and the top one to add 2 srtroke oil with the fresh diesel and to cycle the key a dozen times and start her up and pray
got home at 3am truck was running fine, put on 250 km today running fine
I hope i got away with it this time, thanks for the help guys
Old 01-14-2010, 02:43 PM
Got lucky !!
Old 01-14-2010, 03:35 PM
Infidel
Glad it worked out for you without having to shell $$$$ to fix your rig. I was just grimacing while reading what happened.
Craig
