7.3 OBS RAN FINE AND DIED ALMOST LIKE IT IS GELLED - Ford Powerstroke Diesel Forum
Old 01-10-2010, 07:58 AM
OK SO I WAS DRIVING TO WORK AND IT STARTED SPUTTERING AND I DIED IN MY PARKING LOT... IT HAS 215000 MILES COULD IT BE A IDM I USED DIESEL 911 AND IT DID NOTHING PLUS I USE ANTIGELL REGULARLY
Old 01-10-2010, 08:10 AM
Shaking the Bush Boss
bump up for ya
Old 01-10-2010, 08:38 AM
lots of stuff to check....
  1. fuel? does it have any, tank low etc? you never know when a gauge is gonna quit
  2. Check all wiring harneses in the engine valley at the valve cover gaskets. thouroughly inspect for any burnt, corroded, missing etc pins on both sides
  3. IS the CEL on? if so, codes would be helpful
  4. inspect fuel filter for debris, oil, etc. Verify that the fuel bowl is full......
  5. Check Oil, if oil is too low, it won't run. refill to proper level, attempt to start
  6. It's got to be pretty cold for fuel to gel, especially winter blend. How cold is it where you are?
  7. Has the CPS recall been done? this is the first thing I check when I have a stall or no start situation, it's a 30 dollar part, and It's always good to keep a spare
