Changed Glow Plugs, now loss of power!
Help,
Last week I changed my glow plugs and when I ran it all of a sudden power dropped and the engine was running rough. I tightened the clamp on the hose going into the turbo and everything came back to normal. I drove it for a couple of hours then the next day the yellow service engine light came back on and have a drop in power again. It idles rough and I'm really only topping off at 70 mph. I re tightened the boots and clamps but still running rough. Any Ideas on where to start to look. |
those symptoms could be the result of a dying IDM (injector driver module). get codes from your computer to be sure.
What engine? Any mods?
7.3 with no mods.
UVC harnesses....may have accidentaly knocked one loose, or could be a burt connector in the harness....may have got a wire to colse to a rocker or spring, and its rubbed thru the insulation...causing a short
What code am I looking for if this is the case?
ok just got codes ran and it came up with a P0603 and a P1316
def check your valve cover harnesses and under valve cover harneses
P0603 - KAM memory loss P1316 - Injector Circuit/IDM Codes Detected |
