Do I need to pull it? - Ford Powerstroke Diesel Forum
Old 01-01-2010, 10:06 PM
I have a 01 250 4x4 that I just put a new long block in about 5k ago. Put new oil pan on since I have 200k in NY on it. My caulk job seems to have failed center front under the oil pump and leaking pretty good. has anyone tried to redo this seal with out pulling the motor before?
Old 01-01-2010, 10:56 PM
you need to pull it because the motor has to sit upside down for 24 hours after the pan is put back on
Old 01-01-2010, 11:28 PM
International Threat
Yes, pull the engine back out.
The sealant does need 18-24 hours to cure however it doesn't care which way the motor is oriented.
I put the sealant on, put the pan on, snug all the bolts down by hand, then torque them all, and then install the engine. I just don't put fluid in for 24 hours.
Old 01-01-2010, 11:29 PM
ok listen to him he knows more lol but thats what i have heard and read in a shop manual somewhere, and i never understood it anyway lol
Old 01-01-2010, 11:35 PM
No you're right. That's what it says... but I was just offering what I do that I've been successful with and Scott does the same thing. I used to leave it sit, but don't have time for that anymore.
Old 01-01-2010, 11:42 PM
well atleast i was right lol i have never seen that anywhere else except in a ford shop manual i have pulled many small block chevys apart and half time we just coat the gasket real light with sealant put it back together and put in the car and go at it lol
Old 01-02-2010, 10:42 AM
Thanks yal. Guess that will make my up pipe project easier.
