06 Broken on Vacation please help.
Ok here goes. Started taking long time to start and sometimes fires then dies. Had batteries checked and were weak tech said needed new alternator. So put it on before leaving home. Well started stumbling after arriving at rv resort so I carry a spare set of fuel filters so I went to install the one on top of engine first. Keys in my pocket no way switch was on and when seal broke was drowned in diesel fuel. Scrambled to remove battery cables and stooped pump. changed filters reconnect cables and pump runs all the time. I know now why my batteries were low. Noticed alot of oil down in valley pan area. Is their any way to check pump relay if so where is it. I know it is not only problem but could be a start. All dealers closed up here for new years supposed to go home Sunday.
