Collapsed Lifter - Ford Powerstroke Diesel Forum
post #1 of 1 Old 12-28-2009, 07:46 AM Thread Starter
LBZinthehizhood's Avatar
Collapsed Lifter
01 7.3 w/ 150k Motor was smoking bad and rough idle origionally thought it was an injector. Pulled the passenger side valve cover and on #8 cylinder the front pushrod was loose laying in its hole its as straight as can be but not connected. Is it a collapsed lifter? And whats the easiest way to replace it? If the head HAS to be pulled it looks like I can maybe do it in frame, has any one done it?
2009 GMC 3500 Dually 4" Cognito NTBD 265/75/19.5's EFI Live 5" MBRP
'08 F-250 King Ranch CC 6.4 Black/ Tan
SCT Extreme Off Road Tunes
Magnaflow 5" w/ muffler w/ powerstroker67 delete pipe AFE Stage II Torque Tube Filter Sock
2.5 Leveling Kit 2" Rear Bilsteins All Around Airbags/ Controller
B&W Turnover Ball
Kenwood DNX5120 Nav/DVD Bluetooth, IPOD, B/U Cam
If it has tits, tires, or a transom its going to give you troubles!
Cylinder Count 54
LBZinthehizhood is offline
