Throwin codes and I know why.
I have a 99 7.3 that has been the best truck i have ever had.It's basically stock,it has a 4" exhaust,a diablo tuner(always set on 40hp),and a boost fooler.Thats it.
So my problems are that it sputters and throws the check light.The codes are p1249-wastegatecontrol valve performance and p1316-injector driver module codes detected.I'm no stranger to turning a wrench and not afraid to work on it , but I have no idea were to go from here. I think an injector is going out , but i don't know how to tell.It wouldn't go into fast idle warm-up this morning either. Any info would be greatly appreciated. ![]() Thanks in advance RYAN |
MINE DID THE SAME THING LAST WEEK I CHANGED THE HARNESS UNDER THE VALVE COVER AND IT WENT AWAY 1316 SPUTTER NO BALLS I LUCKED OUT IT WAS ON THE DRIVERSIDE THATS THE EASY SIDE.
IF U DO BUY THE HARNESS GET IT FROM FORD NO AUTOZONE JUNK NOT WORTH THE B-S GOOD LUCK POST UP HOW U MADE OUT |
