Symptoms....oil/fuel mix leaking from the drivers side up pipe, where it connects to the exhaust manifold. Smoking heavily. No real loss of power.
unrelated problem.... turn key on, GP solinoid clicks, lose all power as if the batteries werent there....or not getting 12v, interior light is real dim, if its getting power at all. __________________ |
batteries are bad |
ok, that takes care of one problem.
Injector O rings???
what I was thinking
to the top................
losing any oil? could be a bad injector..... bad injector o rings typically dump oil into the fuel system IIRC, if the injector is bad, it can leak oil into the cylinder (sort of)
what color smoke? Last edited by ianstew; 12-21-2009 at 10:09 PM. |
other than it smoking like a train, oil and fuel mixing..no external oil leaks. I havent pulled the injectors yet...it'll happen later this afternoon.
