03 6.0 Help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-12-2009, 05:21 PM Thread Starter
Exclamation 03 6.0, Dropped t-40 down oill drain!!!
I was replacing the #3 injector. The t-40 slipped out of the socket and went down the oil drain to the lower left of injector. Not visible and flex magnet didn't work. Did this fall all the way to the pan, or is this bad?
Strokin on a Ritz is offline
post #2 of 6 Old 12-13-2009, 03:48 PM
clys's Avatar
Yup this is bad, and no, it did not fall into the pan. Keep fishing with the magnet, you'll get it.
clys is offline
post #3 of 6 Old 12-14-2009, 05:14 AM
greasltn's Avatar
If you can't fish it out, you will need to pull the head. Hope you can fish better than me.
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
post #4 of 6 Old 12-15-2009, 02:41 PM Thread Starter
Greasltn are we talking from experience? Did you have to pull your head?
post #5 of 6 Old 12-15-2009, 07:05 PM
clys's Avatar
If you use a snake camera, you should be able to find it no problem
clys is offline
post #6 of 6 Old 12-15-2009, 07:18 PM Thread Starter
I'm hoping tomarrow that a mobile mechanic can come out and scope, explore and find and maybe remove...
Think positive.
