mystery oil leak - Ford Powerstroke Diesel Forum
Old 12-08-2009, 02:00 PM
mystery oil leak
I have an oil leak..the passanger side of my oil pan is wet and it is on passanger side exhast manifold at the up pipe,and even on rear shackle for front spring. I cant seem to see a spacific spot it is coming from?
Old 12-08-2009, 08:58 PM
which engine is it?(year)
Old 12-09-2009, 05:28 AM
its a 2000 7.3 with 6speed manual 4x4. I have tried to tighten the pan and the bolts are tight. It looks like it is leaking from the pan gasket. If the pan is leaking how hard is it to change pan gasket?
Old 12-09-2009, 09:32 PM
it could be leaking from the flywheel housing. if it is the oil pan, you need to just about remove the engine to get the oil pan out.
