kinda stuck - Ford Powerstroke Diesel Forum
post #1 of 1 Old 11-30-2009, 08:51 AM Thread Starter
ARMY MOM!!!!
korg70kbc's Avatar
Send a message via Yahoo to korg70kbc
kinda stuck
here are the new codes on AE, weird thing is the SES won't go out unless u do the KOEO test which throws the codes P1280, P0705 & P1139. I have a ICP to put in the 705 is no biggie I found a way to adjust that on the AE & I do have a new fuel filter, so hopefully that will stop those the ones below have me a bit puzzled, as does the SES not clearing or even showing on the AE.
THe other issue is the 4x4 light is out again & when you turn key on, the buzzing is going on & on & on.
batts are dieing, but that may be I left the truck & went on a short vacation after my harness. So they are on trickle while I post this. It does fire up & run, but I just left town, so I guess I better get back to it so I can actually drive this thing at some point this yearthe 2 bold ones are the ones that puzzle me.
ANyone have a clue??/
AutoEnginuity OBD-II DTC Report MIL: Off
Diagnostic Trouble Codes
Generic Powertrain
No diagnostic codes retrieved
Anti-Lock Brake No diagnostic codes retrieved
GEM/Central Timer
B1352 Ignition Key-In Circuit Failure
B1323 Door Ajar Lamp Circuit Failure
B1438 Wiper Mode Select Switch Circuit Failure
B1450 Wiper Wash/Delay Switch Circuit Failure
P1894 Axle Disconnect Disengagement Solenoid Circuit High
C1018 Unknown Trouble Code Description
Airbag
B1871 Passenger Air Bag Disable Module Fault
B1884 PAD Warning Lamp Circuit Failure
Overhead Trip Computer
No response from module
??????? what did I miss???
Enhanced Powertrain
P1280 Injector Control Pressure Sensor Circuit Low why????
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P1139 Water in Fuel Indicator Circuit
I did find a mechanic, seems good, but just got back so I haven't called to see how much a flash of the pcm would be, as I'm thinking its that, the GEM again, or possibly I need a diff fuse panel....................
I always worried that the ses wouln;t come on, now it won't go away.
Laurie
SOLD NCHornet's CCV MOD!, stancor GP relay, zoodad, 6637, fumoto valve, 4" turbo back no cat/muffler, Autometer gauges, & AE avail.
korg70kbc is offline
