Fuel leak ( large) - Ford Powerstroke Diesel Forum
Old 11-28-2009, 06:17 AM
Bax Bax is offline
Fuel leak ( large)
I have a fuel leak. (2000 7.3 ) I have had a small seep out of the backside of the pump however this morning it became a large leak. Fuel is just dumping out of the back of the pump. I am assuming it is an O ring problem. It is not the filter seal. It is behind the filter and down a little. I have searched for an exploded view of the pump but have come up empty. Any information would be much appreciated.
Thanks
Bax
Old 11-28-2009, 10:42 AM
Bax Bax is offline
I got it fixed. It was the two rings in the water separator drain assembly. The valve is made of plastic so I guess the failure is just a matter of time.
I love it when I answer my own question.
Bax
