Oil Pressure ?
I need help please i have a 96 PSD with 280000 the problem i have is when down shifting to turn or stop the truck makes a shuttering noise and the oil pressure gauge goes crazy from low to high the truck makes the same shuttering noise at shutdown even after letting it run for 3-5min and ideas please i don't want to kill my truck.
Parts replaced on truck (by org owner have receipts) clutch oil cooler water-pump injector o'rings has 4 re-man injectors all glow-plugs injector harness GP relay |
Shuddering??Sounds like your icp sensor going bad...or your ipr..something to do with oil press.If it wasnt for the oil press guage doing that I would think fuel press reg FPR needs to be cleaned and/or fuel filter.Try putting some diesel injector cleaner/water remover in too.
You've most likely done it, but check your oil - again. ICP sensor could be going.
