6.0 no start cold- advice? - Ford Powerstroke Diesel Forum
Old 11-22-2009, 11:12 AM
two weeks ago I had a no start with a warm engine. Diesel shop replaced a stc fitting and a bunch of o rings etc as the oil pressure was only about 350 psi.
Has been running great with no issues for two weeks.
This AM it won't start. Same thing, it will crank but not start. Charging the batteries as I killed them.
I got fuel in the filter housing so looks like the fuel is there.
It's Sunday so can't get it in anywhere anyways so doing my homework.
Maybe the HPOP is shot? Any ideas?
Old 11-25-2009, 08:25 AM
Well no help from you guys
Anyways shop says it's the HPOP. I'm not sure but seems to me when they spent 10 hours last time they could have checked the HPOP while they were replacing the STC fitting. Woud have saved me 8 hours of labor.
Old 11-25-2009, 03:43 PM
Hey bud, just saw your post.
What year is your truck?
If it's an '04 or later, pull the ICP sensor out from the P/S valve cover using a 15/16" wrench, and insert a hose with the same thread/pitch as the ICP with (preferably) a gas well testing gauge (2000PSI minimum) and crank.
You seem to already understand that the 6.0 requires a minimum of ~350psi to start, and with this easy and cheap setup, you can determine this for yourself while someone else cranks it over for you.
Please report back with results and we can go from there. I'm leaning towards your IPR being shot at this point.
Let us know.
Old 11-25-2009, 04:37 PM
Thanks for the feedback. Unfortunately I had to leave it at a shop. They pressure tested and unlike two weeks ago this time it held pressure. They already replaced orings etc under the valve covers and the STC fitting.
They now pulled the HPOP and said they could hand test it by rotating and counting the stop points. This one spun freely.
Anyways they quoted me $988 for a new one here in Canada so I hopped Stateside and picked one up at Ford for $583.
I sure hope this solves it as it's getting pricy and I have a 2300 mile tow planned for next week.
